16 years agoAltera TSE driver and example program for lwIP (1.3.2)
After many many requests and complaints about lack of support and/or documentation for support of lwIP for the Altera TSE, I have developed a drop-in TSE driver and example program and made this avai...
14 years agoIgor & Dsl,
I'm starting to think that something else is going on here. I don't see problems here and now have lwIP in 4 Cyclone/NIOS-II products. I even implemented telnet as a debug console and have no problem with the 1-byte payloads that occurs when you type in Telnet. However, none of my chains are 1 byte because lwIP has made them bigger adding TCP/IP headers. Maybe you have an lwip option set which causes this? Also, I use PBUF_POOL_SIZE of 1518 so that I get as few chains as possible. I have 256MB of memory and have no concern over memory usage. Igor, what do you mean by: --- Quote Start --- Also, has anyone tried to use “On-Chip FIFO Memory Core” in place of sgdma for ethernet? --- Quote End --- Bill
