16 years agoAltera TSE driver and example program for lwIP (1.3.2)
After many many requests and complaints about lack of support and/or documentation for support of lwIP for the Altera TSE, I have developed a drop-in TSE driver and example program and made this avai...
14 years ago --- Quote Start --- Created a git repository with the latest sources has been created. https://github.com/engineeringspirit/freelwip-nios-ii this version works stable but is far from optimized. --- Quote End --- I think it would be really helpful and would promote much more use of your additions if this was put on the lwIP Wiki: http://lwip.wikia.com/wiki/available_device_drivers I will check what you did for sure - I hope FreeRTOS use is optional in your installation. There are several ways to use lwIP without an RTOS and it's well documented that a significant performance hit occurs using an RTOS. Integrating a significant number of lwipopts.h settings into the Eclipse install would also help new users as well. I wonder if a lwIP template application was possible in the "New" menu? By the way, I use lwIP as a library - I don't know if you allowed for that. In fact I have the TSE driver as a LIB also but unfortunately it needs to be tied to a BSP. This makes it hard to use the TSE/lwIP combo in multiple projects that have (and normally would) different BSPs without duplicating the 2 LIBs. It's great to see your additions here. You really did more than I did and I'm thankful someone took it as a catalyst and ran with it like I wish I could have. lwIP 1.4.1 is due out shortly and 1.5 isn't far off with stable IPV6. Bill
