16 years agoAltera TSE driver and example program for lwIP (1.3.2)
After many many requests and complaints about lack of support and/or documentation for support of lwIP for the Altera TSE, I have developed a drop-in TSE driver and example program and made this avai...
15 years agoThanks Ivan. I will update this example to use the SBT (not CDT as it is for 8.x). I also added a CUSTOM_PHY# define to the example to allow adding an unsupported PHY(e.g. 88E1119 as you pointed out) to the program. Maybe I should just leave it in for all builds since adding PHY is not a problem if it's not used.
You can also replace lwIP with version 1.4 (which is out as a release candidate) and it builds and runs without problems. By the way, our Cyclone-based products also use the 88E1119 as it was used on the demo board we evaluated. Thanks again for the feedback. Bill
