16 years agoAltera TSE driver and example program for lwIP (1.3.2)
After many many requests and complaints about lack of support and/or documentation for support of lwIP for the Altera TSE, I have developed a drop-in TSE driver and example program and made this avai...
15 years agoChris,
Are you using 10.0 and using the VIC? With a new design using lwIP we're using 10.0SP1 and I'm trying to get some form of this demo running. Right now I'm just getting our configuration side ironed out because it's not running as-is - but it could be the SOPC side of things. If you have design the VIC in, it might run if you disable it in the BSP editor. A user did report this runs in 9.0 so I suspect there might be a VIC compatibility issue (assuming he didn't use the VIC - if he did then it should run as-is). If there is a problem in the lwIP driver I'll update this demo ASAP as I need lwIP for the new product using 10.0 and the VIC. Thanks, Bill
