21 years agoAltera-SOPC Handling
Hi all,
I am new at the Software, and would be very grateful for some help. When I try to generate a Code with the SOPC-Generator (Chip : NIOS2, Memory, Jtag-UART) an Error occurs. LOGFilemessage: Altera SOPC Builder Version 4.10 Build 181 Copyright © 1999-2004 Altera Corporation. All rights reserved.# 2004.09.24 11:00:59 (*) mk_custom_sdk starting# 2004.09.24 11:00:59 (*) Reading project C:/test/NIOS/templates_microtronix/all_on_chip_32/nios_32.ptf.# 2004.09.24 11:00:59 (*) Finding all CPUs# 2004.09.24 11:00:59 (*) Finding all available components no install.ptf file found at c:/altera/quartus41/sopc_builder/bin/europa/europa_utils.pm line 1700. Error in processing. System NOT successfully generated. tried to reinstall the whole software, but it still doesn't work. I am using a full license of Quartus2, evalversion of NIOS2 IDE and the StratixDevelopboard A6009 from Microtronix. Has anyone a clue how I got this thing working? Thank you very much!!3 Replies
hi, the install.ptf file is typically located in:
c:\documents and settings\<username>\.sopc_builder I've noticed a similar problem once or twice but it always seems to resolve itself after re-booting the PC. I believe that the problem occurred after installing the USB-blaster driver for the first time. You'll probably have to contact Altera tech support about this because I'm reasonably certain that there isn't anything in the Stratix Development Kit that would affect the ability to find the install.ptf file. If you have a reason to believe otherwise, please let me know. - Altera_Forum
That sounds like the problem I ran into as well. I found out the cause for me was the lack of page space (virtual memory) on my computer. Instead of windows expanding the v-ram the build would just end.
The system I was using had 384kB of RAM and hardly any page space (was trying to make the system faster keeping more in physical RAM). If you have a similar setup try increasing the V-ram that the system uses and that'll probably fix your problem. Good-luck - Altera_Forum
Ok,
I copied the install.pft to the default folder and resized the VMemory, and it works!!! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif Thank you very much!!!
