21 years agoAltera SOPC Builder problem
Hello , I've got a problem with the Altera SOPC-Builder. Below error occurs in the SOPC, when I try to generate the code (from Nios II tutorial): <div class='quotetop'>QUOTE </div> ...
21 years agoInstallation and/or user issue of some sort. Be sure that you're using Quartus/SOPC Builder as the same user that installed it. The "install.ptf" file is in ~/.sopc_builder/install.ptf (where ~ represents the user profile directory in Windows and the user's home directory in Linux/UNIX). If running on Linux/UNIX, you need to make sure that whatever user you're logged in as, actually has a home directory.
- slacker
