14 years agoaltera simple socket server troubles
I need to provide TCP/IP connection with speed ~10 Mbit/s with Cyclone IV Development board. It provides 10/100/1000 BASE-T Ethernet connection via a Marvell 88E1111 PHY and the FPGA-based Al...
14 years agoThere is a number of reasons which can cause your application to stop.
First of all you must know if the whole application crashes or it's a matter of a single task; use a separate tasks to toggle a signal or blink a LED in order to understand this. Also try to keep the send queue limited. I mean, before sending more data, wait until you received a certain amount. For example, if you were transmitting 1,2,3, etc. , don't send N until you have received N - K, where K is the queue limit you choose. If this way the system works, then you have a problem with your task stack size or with memory available for managing network packets.
