14 years agoaltera simple socket server troubles
I need to provide TCP/IP connection with speed ~10 Mbit/s
with Cyclone IV Development board. It provides 10/100/1000 BASE-T Ethernet connection via a Marvell 88E1111 PHY and the FPGA-based Altera Triple Speed Ethernet MegaCore function in RGMII mode. I use altera simple socket server example to transmit 1500 bytes payloads. It tranfer several packets and stop whithout any activity. Server code:
# include <stdio.h># include <errno.h>
# include <alt_iniche_dev.h># include "ipport.h"# include "libport.h"# include "osport.h"# include "tcpport.h"
# define IP4_ADDR(ipaddr, a,b,c,d) ipaddr =
htonl((((alt_u32)(a & 0xff) << 24) | ((alt_u32)(b & 0xff) << 16) |
((alt_u32)(c & 0xff) << 8) | (alt_u32)(d & 0xff)))
# define IPADDR0 192# define IPADDR1 168# define IPADDR2 0# define IPADDR3 200
# define GWADDR0 0# define GWADDR1 0# define GWADDR2 0# define GWADDR3 0
# define MSKADDR0 255# define MSKADDR1 255# define MSKADDR2 255# define MSKADDR3 0
# include "global.h"
int get_mac_addr(NET net, unsigned char mac_addr)
// This is the Altera Vendor ID
mac_addr = 0x0;
mac_addr = 0x7;
mac_addr = 0xed;
// Reserverd Board identifier
mac_addr = 0xFF;
mac_addr = 0x00;
mac_addr = 0x02;
printf("Your Ethernet MAC address is %02x:%02x:%02x:%02x:%02x:%02x\n",
mac_addr,
mac_addr,
mac_addr,
mac_addr,
mac_addr,
mac_addr);
return 0;
int get_ip_addr(alt_iniche_dev *p_dev,
ip_addr* ipaddr,
ip_addr* netmask,
ip_addr* gw,
int* use_dhcp)
IP4_ADDR(*ipaddr, IPADDR0, IPADDR1, IPADDR2, IPADDR3);
IP4_ADDR(*gw, GWADDR0, GWADDR1, GWADDR2, GWADDR3);
IP4_ADDR(*netmask, MSKADDR0, MSKADDR1, MSKADDR2, MSKADDR3);
*use_dhcp = 0;
printf("Static IP Address is %d.%d.%d.%d\n",
ip4_addr1(*ipaddr),
ip4_addr2(*ipaddr),
ip4_addr3(*ipaddr),
ip4_addr4(*ipaddr));
/* Non-standard API: return 1 for success */
return 1;
# define BUF_SIZE 1500 //1500
# define TASK_STACKSIZE 2048
OS_STK InitialTaskStk;# define INITIAL_TASK_PRIORITY 5
void work_server()
char buff;
int socket, len;
struct sockaddr_in incoming_addr;
//server_socket
int fd_listen, max_socket;
struct sockaddr_in addr;
fd_set readfds;
if ((fd_listen = socket(AF_INET, SOCK_STREAM, 0)) < 0)
printf(" Socket creation failed\n");
while(1);
addr.sin_family = AF_INET;
addr.sin_port = htons(9000);
addr.sin_addr.s_addr = INADDR_ANY;
if ((bind(fd_listen,(struct sockaddr *)&addr, sizeof(addr))) < 0)
printf("Bind failed \n");
while(1);
if ((listen(fd_listen, 1)) < 0)
printf("Listen failed\n");
while(1);
len = sizeof(incoming_addr);
FD_ZERO(&readfds);
FD_SET(fd_listen, &readfds);
max_socket = fd_listen+1;
while(1)
printf("wait accept client\n");
select(max_socket, &readfds, NULL, NULL, NULL);
if (FD_ISSET(fd_listen, &readfds))
if((socket = accept(fd_listen, (struct sockaddr*)&incoming_addr, &len)) < 0)
printf("accept failed\n");
continue;
else
printf("accept OK\n");
int bytes_recv, nsize = 0;
while((bytes_recv = recv(socket, buff, BUF_SIZE, 0)) != SOCKET_ERROR)
//printf("\n\nbytes_recv = %d\n", bytes_recv);
bytes_recv = send(socket, buff, bytes_recv, 0);
nsize++;
printf("nsize = %d\n", nsize);
printf("\n\n\nSOCKET_ERROR\n\n\n");
TK_OBJECT(to_task);
TK_ENTRY(work_server);
struct inet_taskinfo server_task = {
&to_task,
"server",
work_server,
6,
APP_STACK_SIZE,
void InitialTask(void *task_data)
alt_iniche_init();
netmain();
printf("wait inich\n");
while (!iniche_net_ready)
TK_SLEEP(1);
TK_NEWTASK(&server_task);
OSTaskDel(OS_PRIO_SELF);// del self task
while (1);
int main (int argc, char* argv, char* envp)
/* Clear the RTOS timer */
OSTimeSet(0);
/* SSSInitialTask will initialize the NicheStack
* TCP/IP Stack and then initialize the rest of the Simple Socket Server example
* RTOS structures and tasks.
OSTaskCreateExt(InitialTask,
NULL,
(void *)&InitialTaskStk,
INITIAL_TASK_PRIORITY,
InitialTaskStk,
TASK_STACKSIZE,
NULL,
0);
* As with all MicroC/OS-II designs, once the initial thread(s) and
* associated RTOS resources are declared, we start the RTOS. That's it!
OSStart();
while(1); /* Correct Program Flow never gets here. */
return -1;
Client code:
# include <stdio.h># include <string.h># include <winsock2.h># include <windows.h>
# pragma comment(lib, "ws2_32.lib")
# define PORT 9000# define SERVERADDR "192.168.0.200"
//#define SERVERADDR "127.0.0.1"
DWORD WINAPI RecvMess(LPVOID pmy_sock);
# define COUNT_DATA 256 // 10240 по 1024 = 10 Mb# define NN 1024 // size buffer
int ready = 1;
int main(int argc, char* argv)
DWORD thID;
char buff;
printf("TCP DEMO CLIENT\n");
if (WSAStartup(0x202,(WSADATA *)&buff))
printf("WSAStart error %d\n", WSAGetLastError());
return -1;
SOCKET my_sock;
my_sock = socket(AF_INET,SOCK_STREAM,0);
if (my_sock < 0)
printf("Socket() error %d\n",WSAGetLastError());
return -1;
sockaddr_in dest_addr;
dest_addr.sin_family=AF_INET;
dest_addr.sin_port=htons(PORT);
if (inet_addr(SERVERADDR) != INADDR_NONE)
dest_addr.sin_addr.s_addr=inet_addr(SERVERADDR);
// соединение
if (connect(my_sock,(sockaddr *)&dest_addr, sizeof(dest_addr)))
printf("Connect error %d\n",WSAGetLastError());
WSACleanup();
fgets(buff, sizeof(buff)-1, stdin);
return -1;
printf("Connect with %s successfully\n\n", SERVERADDR);
CreateThread(NULL, NULL, RecvMess, &my_sock, NULL, &thID);
int nsize = 0;
for(int i = 0; i < NN; i++)
buff = (char)(i&0xFF);
DWORD time = GetTickCount();
while(nsize < COUNT_DATA)
nsize++;
send(my_sock, buff, NN,0);
Sleep(1);
printf("Wait recv full\n");
while(ready)
Sleep(1);
time = GetTickCount() - time;
printf("time = %ld\n", time);
closesocket(my_sock);
WSACleanup();
return 0;
//FILE *fd;
char buff;
int bytes_recv;
SOCKET my_sock;
my_sock = *((SOCKET*) pmy_sock);
/*fd = fopen("recv_file.txt", "wb");
if(fd == NULL)
printf("error fopen\n");
return 1;
int nsize = 0;
bytes_recv = recv(my_sock, buff, NN, 0);
if (bytes_recv == SOCKET_ERROR)
printf("error recv\n");
break;
/*if(bytes_recv != fwrite(buff, sizeof(char), bytes_recv, fd))
printf("error fwrite\n");
break;
nsize++;
//fclose(fd);
ready = 0;
return 0;
There is a number of reasons which can cause your application to stop.
First of all you must know if the whole application crashes or it's a matter of a single task; use a separate tasks to toggle a signal or blink a LED in order to understand this. Also try to keep the send queue limited. I mean, before sending more data, wait until you received a certain amount. For example, if you were transmitting 1,2,3, etc. , don't send N until you have received N - K, where K is the queue limit you choose. If this way the system works, then you have a problem with your task stack size or with memory available for managing network packets. - Altera_Forum
I met the same problem....my program is nearly the same as you posted above.
I use DM9000A/Nichestack now,and it stop receiving packets after calling send function several times.it blocks in select function,and can't return. can you tell me how to solve this problem?
