12 years agoAltera rozipfs in SRAM partition
Hi, has anyone attempted and succeeded in using rozipfs with memory base and offset located in SRAM? In my case it doesn't work. I have done the following: - created partition in SRAM ...
12 years agoActually I am copying the contents in the booloader, so before the application is even loaded...
but since it worked in your case, the good news for me is there is no limitation to flash devices, so if I do everything right it should work... :-)
