16 years agoAltera_ro_zipfs NIOSII for Eclipse
Hi! I want to use "Read only zip file system" to fead files from Flash memory. I activated "altera_ro_zipfs" from NIOSII BSP editor with next parameters: ro_zipfs_base - base address of my Fla...
15 years agoHi Mahendran_c,
for me it was just the opposite. I couldn't use a base address of 0x0 for the flash. Actually my flash's address is 0x28000000 and the offset for the rozipfs is 0x50000 so it is copied right after my program code and doesn't owerwrite each other. Be sure to change the offset under the system library settings as well as on flashing window. The size of my Flash is 8 MB and I use Nios 9.1 SP2 with the Webserver example from Interniche.
