11 years agoAltera monitor program terminal window stops showing results display or message after
When I was running Altera monitor program with Nios II and Quartus II, the Altera monitor program terminal window stops showing results display or message after certain time (maybe one hour or more), is this normal? 2. Although it stops showing results, I can see that on top of it, it shows [.srec Running]. I want to make sure is it still running the C Code even though no results or message is displayed on the terminal window? 3. How could I get rid of this problem to make sure it will display results even after hours of running the program? Please could you please let me know if you have encountered the same issues before, thank you very much.No RepliesBe the first to reply
