11 years agoAltera JTAG UART used by kernel does not match IRQ assignment made in Qsys
Hi all, I'm currently developing a 3.10.31-ltsi kernel that running on a Nios II-based system. This system also contains several components including an Altera JTAG UART, USB host controller a...
11 years agoHello Brad,
At the beginning you mentioned following : --- Quote Start --- In Qsys, I assigned the following Nios II interrupts for these system components: timer: IRQ 0 jtaguart: IRQ 1 usbhc: IRQ 2 --- Quote End --- Later you mentioned following, --- Quote Start --- In addition, when I forced the Altera JTAG UART interrupt to IRQ 0 to match the Qsys setting by modifying the altera_jtaguart driver, when the kernel attempts to attach IRQ 0 to the JTAG UART, the following error message was displayed: altera_jtaguart: unable to attach Altera JTAG UART 0 interrupt vector=0 --- Quote End --- Should not you try to force Altera JTAG UART interrupt to IRQ 1, not IRQ 0 ( to match that with Qsys setting.)? Cheers, Bhaumik
