Altera FPGA EP4CE55F23C7N
I currently working on an Altera FPGA. In this project, we were given only the soft software source code using Nios II Software Build Tools for Eclipse I like to run and build the original code before making any changes to it. However, only a .pof programming file and a .cdf file was given to us, so when setting the Hardware design setup, please correct me if I’m wrong, I need the SOPC file and .sof file to configure the hardware?. I tried using the .pof or .cdf files in some way but with no success. Is there a way I can compile and build this application somehow using the .pof file or other way and thus be able to create a bsp project and load the .elf file to the FPGA. Or do I need this .sopcinfo and .sof files. Thank you.
- Farabi_Altera
You may want to refer to this document : https://cdrdv2.intel.com/v1/dl/getContent/666887?fileName=n2cpu-nii5v1gen2-683836-666887.pdf
and design example for you to quickly test the hw you have:
tutorial inside the design example: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an717.pdf
regards,
Farabi
- Farabi_Altera
regards,
Farabi
