20 years agoAltera DE2: SDRAM Ctrler Vs. DDR SDRAM Ctrler
After 4 days struggling to make SDRAM work on the Altera DE2, i finally succeded. I'm only able to do it using the SDRAM controller (not in megacore). I first tried clocking the SDRAM wit...
20 years ago --- Quote Start --- originally posted by slacker+aug 22 2006, 01:26 pm--><div class='quotetop'>quote (slacker @ aug 22 2006, 01:26 pm)</div>
--- quote start ---
why would you want to use a ddr controller for an sdram? you use the controller that's appropriate for the memory on your board. this is, in your case, an sdram (single data rate) controller.[/b]
--- quote end ---
got point, i was confused weither it was sdram or ddr. i've my answer now.
<!--quotebegin-slacker@Aug 22 2006, 01:26 PM if your design doesn't work with a phase shift of -3.0ns, then this could be a problem with the altera/terasic provided examples. one that should be reported. --- Quote End --- I will report if i've the time. Thanks, -Pascal
