20 years agoAltera DE2 & NIOS newbie :(
okie.. im aware the next few lines are gonna be very silly, but i really have no idea how to go about this board Altera DE2 and the NIOS 2. I am to use the board for a real time monitoring applicatio...
20 years agoi seem to be having a problem compiling a normal C program i get the following screen:
**** Incremental build of configuration Debug for project hello_world_0 **** make -s all "X`which cygpath.exe 2> /dev/null`" was unexpected at this time. F:/Projects/GSE4806/Altera/kits/nios2_60/components/altera_hal/build/app_rules.mk:152: `: No such file or directory F:/Projects/GSE4806/Altera/kits/nios2_60/components/altera_hal/build/app_rules.mk:152: "F:/Projects/GSE4806/Altera/kits/nios2_60"`: No such file or directory F:/Projects/GSE4806/Altera/kits/nios2_60/components/altera_hal/build/app_rules.mk:152: /components/altera_hal/build/gnu_rules.mk: No such file or directory F:/Projects/GSE4806/Altera/kits/nios2_60/components/altera_hal/build/app_rules.mk:156: `: No such file or directory F:/Projects/GSE4806/Altera/kits/nios2_60/components/altera_hal/build/app_rules.mk:156: "F:/Projects/GSE4806/Altera/kits/nios2_60"`: No such file or directory F:/Projects/GSE4806/Altera/kits/nios2_60/components/altera_hal/build/app_rules.mk:156: /components/altera_hal/build/gtf_rules.mk: No such file or directory make: *** No rule to make target `/components/altera_hal/build/gtf_rules.mk'. Stop. Build completed are there suppose to be so many errors?? its just a simple hello world program http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif and when i run the Quartus Programmer for the sof file i get the following error Info: Started Programmer operation at Mon Sep 18 02:13:21 2006 Error: Can't configure device. Expected JTAG ID code 0x020840DD for device 1, but found JTAG ID code 0x020B40DD. Error: Operation failed Info: Ended Programmer operation at Mon Sep 18 02:13:21 2006 the hardware setup is set to the USB port of the blaster, any pointers on how i can over come this? Hopeful http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif Agape
