14 years agoAltera Cyclone IV Programming .elf file to flash?
I am working on a DE2-115 dev board and have finished my design. Now i need to program Flash memories so that my code will be non-viotile. I have successfully converted the .sof file to .po...
14 years agook
why you dont use only the epcs flash........... you put the .sof and .elf in epcs put .sof and .elf at same directory .....at command shell enter in this directory convert the .sof sof2flash --input=(your.sof) --output=(yoursof.flash) --epcs --verbose --offset=0x0 write the yoursof.flash nios2-flash-programmer --epcs --debug --base=(yourepcsaddress) yoursof.flash yourepcsaddess = epcs base address + pipeline bridge(if you use) + clock crossing bridge (if you use) to convert .elf type elf2flash --after=(yoursof.flash) --input=(your.elf) --output=yourelf.flash --epcs --boot=/home/altera/11/ip/altera/nios2_ip/altera_nios2/boot_loader_epcs.srec write the yourelf.flash nios2-flash-programmer --epcs --debug --base=(yourepcsaddress) yourelf.flash reboot your system (reset vector =>epcs_controller exception vector => ram)
