21 years agoAltera Avalon Uart performance problem
I have been testing the Altera Avalon Uart by sending data to it from a different machine. A program on the other machine sends 16kB of known data out its serial port which connects to the serial ...
21 years ago --- Quote Start --- originally posted by trk_golf@Mar 1 2005, 02:51 PM this post is supplemental to the previous one.
one thing that is causing me confusion when using the niosserial.c driver is the following.
even when i'm not transmitting any characters, and only receiving them, the transmit_chars() routine is being called.
why does this happen? shouldn't this routine only be called when characters are ready to be sent out?
any comments you might have in regards to these last questions will also help me out a lot.
thanks, --- Quote End --- <div class='quotetop'>QUOTE </div> --- Quote Start --- Even when I'm not transmitting any characters, and only receiving them, the transmit_chars() routine is being called.[/b] --- Quote End --- not quite sure. Could be Xon/Xoff. You can check what was actually transmitted
