21 years agoAltera Avalon Uart performance problem
I have been testing the Altera Avalon Uart by sending data to it from a different machine. A program on the other machine sends 16kB of known data out its serial port which connects to the serial ...
21 years agoOne thing should be pointed out is, the application echo you are using put an extra '\n' at the end with a seperate write operation, therefore, there are actually two characters sent in your example. This is also the reason why you see rs_write twice.
My guess is, if you want to send X characters, the function transmit_chars will be called roughly X+1 times (one extra to disable TX interrupt when no data to send). You can easily test this with a command like "$echo 123456789 >/dev/ttyS1". For a uart with one character buffer, this is nearly the best it can do. But if you have a FIFO, you can make the hardware to generate a TX interrupt when at least a certian proportion of the FIFO is empty, and let transmit_chars send more than one characters each time, then you will see less TX interrupts.
