21 years agoAltera Avalon Uart performance problem
I have been testing the Altera Avalon Uart by sending data to it from a different machine. A program on the other machine sends 16kB of known data out its serial port which connects to the serial ...
21 years agoI have begun to use SignalTap II in order to try and diagnose the Uart problem.
I would also like to try to use the JTAG uart "/dev/ttyJ0" to see how it performs as a reference point. The problem with this is that I haven't figured out how to send data from Cygwin across the Jtag connection. I tried the following with no success: echo "hello" > nios2-terminal cat textfile > nios2-terminal On the Nios II side, I'm just running "cat /dev/ttyJ0". This works fine if I run nios2-terminal and manually enter data. Anymore suggestions on how to send external data through the JTAG uart connection under Cygwin? I would also like to try the Opencores uart16550 to see if it has FIFO problems. This wouldn't work for our end solution, because it takes a lot more LE's compared to the NIOS uarts. But, it would allow a good comparison. Has anyone converted this to interface with an Avalon bus?
