21 years agoAltera Avalon Uart performance problem
I have been testing the Altera Avalon Uart by sending data to it from a different machine. A program on the other machine sends 16kB of known data out its serial port which connects to the serial ...
21 years agoI should have made me more understandable. My suggestion is, trying your communication on JTAG, which has FIFO, to see if you still lose characters. If not, that means your problem is caused by the lack of FIFO in Nios UART. But you said you had tried a FIFO'd uart,
<div class='quotetop'>QUOTE </div> --- Quote Start --- I just don't understand why I would be dropping characters, even with a FIFO'd uart.[/b] --- Quote End --- can you tell me which UART you tried?
