21 years agoAltera Avalon Uart performance problem
I have been testing the Altera Avalon Uart by sending data to it from a different machine. A program on the other machine sends 16kB of known data out its serial port which connects to the serial ...
21 years agoThe JTAG uart works ok for the console port, but I stopped using it because of the annoying CTRL-C issue with nios2-terminal.
Our end application is going to be using multiple RS232 UARTs for communication with multiple external devices. All of these will be running at 115200 baud. I was trying to test a single port to validate the design. The Nios uart and even the FIFO-enabled Cal_Avalon_Uart that I've been working with are preferable to the Open Cores uart because of their small footprint. I just don't understand why I would be dropping characters, even with a FIFO'd uart.
