16 years agoalt_write_flash - single threaded
I'm currently experimenting with uC/OS-II with NicheStack on Nios II. Things are going well except for situations where I am writing 128K of data to flash using alt_write_flash(). I noticed in the...
16 years ago4)
I have tested the whole flash within the InitialTask (before the network stack is running) --> That works fine! 3) Everything works fine, if the network-stack doesn't process any data 2) All calls to the flash-device came from the context of a single tasks (and also not from an interrupt-context). The priority of this task is the lower than those of the network-tasks. Only "statistic-task" and "idle-task" have a lower priority 1) The Stack usage reaches a maximum of 41% But i will try to increase the stack-size.... Perhaps there is something wrong with my code.....
