16 years agoalt_nticks(); Correct method to measure time
What is the accurate way to measure time in Nios II? I am implementing a co-processor using stream-like process in Nios II. For measuring time, I am using alt_nticks from <sys/alt_alarm.h> Here is how my code works: start_time = alt_nticks(); open_stream(); // perform read, write to the stream // perform calculations close_stream(); finish_time = alt_nticks(); total_time = (finish_time - start_time)/ alt_tick_per_second(); The problem is the time measured from the method above produces only 40s, whereas it takes ~10 mins to run the code. The alt_ticks_per_second is 100, but i think it is way lower than that. It is either alt_nticks() or alt_ticks_per_second() that is not accurate. Anyone has a better idea?No RepliesBe the first to reply
