21 years agoalt_load() - Anyone having info?
Hi This function is briefly mentioned in the Nios II Software Developer’s Handbook. It is the boot loader that copies segments from FLASH to RAM at power-up. Best Regards http://forum.n...
21 years agoalt_load() is only used when there is no bootloader in your system, for example when you run from flash. This happens when you set the .text section to be in the same memory as the reset vector.
Otherwise a seperate loader is used to load the code from flash. The source for this can be found in the directory: components\altera_nios2\sdk\src\boot_loader_sources in the Nios II kit. When called, alt_load() will copy out the: .rwdata, .rodata, and .exception sections from the boot device to external memory devices, as required.
