13 years ago
alt_irq_register can't work
I have added a component CAN controller into SOPC builder, and it work well. I can send and receive data correctly. But i can't register the interrupt(IRQ) send out from the controller. I checked anything i know....
Here is my code, it can be compiled and no errors, but just die in the alt_irq_register function. Anybody have experience to use CAN controller in
SOPC builder can tell me where is the problem?
static void handle_CAN2_interrupts(void* context, alt_u32 id)
int q;
q =IORD(CAN2_BASE, 0x4);
printf(" interupt = %d \n",q);
int main()
printf("Hello from Nios II!\n");
alt_irq_register(CAN2_IRQ,NULL, handle_CAN2_interrupts );
tx_basic_frame();
i use quartus 8.0 and NIOS ii 7.2 to do this
    also i test to use the timer interrupt, and it worked fine. i can't figure why me controller can't even register irq...
    I don't know your CAN controller, but I guess you probably need to clear the irq inside the handler function, otherwise the irq would continuously retrigger just after you have serviced it.
    --- Quote Start ---
    --- Quote End ---
    Thanks for your advise, i find my controller send a unexpected interrupt after reset, and it cause the retrigger problem you said.
