12 years agoalt_flash_open_dev() returns 0
I've been using a CFI flash, S29GL.... I'm able to access its contents through Memory read utility in the IDE, and also write into it correctly through Flash Programmer utility.. But, alt_fla...
12 years agoPradeep, I have had the same issue of alt_flash_open_dev() returning 0 all the time. I had enabled reduced drivers in the bsp settings. I do not know if you have it enabled or not. If you do not have it enabled, this solution might not apply to you. But if you do, try disabling them for a quick check.
