20 years agoAlso Problems with Hello World
If I try to run the example Project Hello World I got the following error? I have also recompiled my System but it doesnt help? Has anybody an idea why this can happen? <div class='quotetop'>QUOTE...
20 years agoSimple answer: This error message occurs when the hardware image which has been programmed into the board doesn't match the one being used to generate the software for your system.
Simple solution: Make sure that you reprogram the board with the current hardware image being used to generate the software for the system. To accomplish this goal, recompile your Quartus II project and download the generated SOF file to the board. Just remember that any changes you make to your Nios II system in SOPC Builder will cause the Nios II IDE to present this error again. Additionally, if you are positive that you haven't changed the system, you can by-pass the check of the system ID in the Nios II IDE. To do this, in the Nios II IDE select "Run -> Debug..." and pick your download configuration. In the first tab, uncheck the "Validate Nios II system ID before software download" item. This will prevent the Nios II IDE from checking the system hardware for the system ID. Hope this helps, Chris --- Quote Start --- originally posted by niostwo@Jun 12 2006, 03:21 AM if i try to run the example project hello world i got the following error? i have also recompiled my system but it doesnt help? has anybody an idea why this can happen?<div class='quotetop'>quote
--- quote end ---
--- quote start ---
reading system id at address 0x00810828: does not match
id value does not match: read 0xe0800b15; expected 0xbb381db2
timestamp value does not match: image on board is older than expected
read timestamp 5:42:34 1970/01/05; expected 11:53:31 2006/04/21
the software you are downloading may not run on the system which is currently
configured into the device. please download the correct sof or recompile.
restarting target processor --- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16107)</div> [/b] --- Quote End ---
