21 years agoAgain function with "attribute"
Hi all,
I have Quartus 4.2 Nios 1.2, my system: - Nios II (e), no debug module, 32 MHz - onchip_memory 4096 bytes RAM - onchip_memory_2 1024 bytes RAM - instruction and data bus connected to onchip_memory and onchip_memory_2 - EPCS controller - reset address,exception address, break location = onchip_memory - program and data memory = onchip_memory - i have used all the compilation settings to reduce code footprint as explained in "Developing Programs using the HAL" chapter if a define a function with: <div class='quotetop'>QUOTE </div> --- Quote Start --- __attribute__ ((section ( ".onchip_memory_2")))[/b] --- Quote End --- my CPU hangs when this function get called. Every fuction I define with "attribute", the same behaviour. Any suggestions? thank uNo RepliesBe the first to reply
