20 years agoAfter installing 5.1 load up kernel produce errors
Hello Friends! I have installed Nios II IDE Version 5.1 WEB and Quartus 5.1 WEB. After I have compiled a kernel I try to load it up, but the following messages occurs: using cable "usb...
20 years agoI'm not sure but it looks like there is an older design (with Nios2) in your system and the new version doesn't particulary like that.
You might want to try to use a newer version of the nios2 and the upload program you use (sof system used to write to flash...)
