16 years agoAddressing in hex file
Hello, I currently design a system with SOPC based on the Nios II processor. I checked the hex file generated by the Nios II IDE after compilation. At the beginning I have the following : ...
16 years agoThis way of working is not the one of the Nios only because I think it is the same for processor inside PC for example (and probably other processors).
But, would it not be more simple if the depth of the memory was the same than the depth of the bus ?
