16 years agoAddressing in hex file
Hello, I currently design a system with SOPC based on the Nios II processor. I checked the hex file generated by the Nios II IDE after compilation. At the beginning I have the following : ...
16 years agoArgh. We don't arrive to understand each other. Maybe is because my question has no sense when we know how it is done physically.
My idea of a memory (imagine it as a town) is, we have an address bus that permit to access a memory element (imagine it is as a building). The size of the address bus will simply indicate how many memory element we can access (bus of N bits => access to 2^N elements (2^N building in the town)). You have a first type of memory where the size of an element is 8 bits (your building has 8 floors). So the data bus is 8-bit length. Why can we not imagine a memory where the size of an element is 32 bits (your building has 32 floors), or 24 or even 15 if we want ? I hope this metaphor will help to be understood.
