21 years agoAddress Exception
Hi We are using a SRAM that has a 16-bit wide data bus and /BLE and /BHE signals for byte-write. Writing bytes to addresses 0 to 7 works, with BLE and BHE behaving as expected, although A0...
21 years agois your wiring correct ?
i use ISSI IS61LV25616AL 256k x 16 wiring: NIOS [A18..A1] -> SRAM [A17..A0] userlogic is setup as following: Bus Interface Type: Avalon Memory Slave PORT NAME | Width | Direction | Shared | Type address | 18 | input | yes | address write_n | 1 | input | yes | write_n read_n | 1 | input | yes | read_n writedata | 16 | inout | yes | data chipselect_n | 1 | input | --- | chipselect_n be_n | 2 | input | yes | byteenable_n system clock frequency is 50 Mhz i use 1 setup, 1 wait, 1 wait cycle
