19 years agoaddress calculation
Hello! I'm developing master peripheral component (32bit) which should read data from sdram(32bit). I found out(with experiment) that if master should read data from address BASE+OFFSET, maste...
19 years agoHey
Have you connected the your master addresses correctly to your slave device? See document mnl_avalon_spec.pdf, p71 For a 32b slave,you should connect your avalon bridge address A2 to slave address A0, master address A3 to slave A1, ..... Kind regards Karel
