15 years ago
adding jfs_utils
I've read all sorts of posts, but still have been unsuccessful getting jfs_fsck integrated into my uClinux for my Cyclone II Dev board.
My last attempt has been:
1. got the jfsutils tar file - added it to nios2-linux/uClinux-dist/user/jfsutils-1.1.14
2. cd to the jfsutils-1.1.14 directory
LDFLAGS="-elf2flt" ./configure --host=nios2-linux-uclibc --disable-shared --prefix=/opt/nios2
The configure output is LONG but at the beginning I get
configure: WARNING: unrecognized options: --disable-shared
configure: WARNING: If you wanted to set the --build type, don't use --host.
If a cross compiler is detected then cross compile mode will be used.
AND AT THE END I GET ---
configure: error: 'Install e2fsprogs-libs e2fsprogs-devel or uuid-dev'
Can anyone steer me in the right direction?
Thanks in advance.
    Please take this as an example,
    uClinux-dist/user/haserl/Makefile
    O.K - now I get the following at the end of the "make"
    checking for sys/disklabel.h... no
    checking uuid/uuid.h usability... no
    checking uuid/uuid.h presence... no
    checking for uuid/uuid.h... no
    make[3]: *** [build-jfsutils-1.1.14/Makefile] Error 1
    make[3]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user/jfsutils'
    make[2]: *** [jfsutils] Error 2
    make[2]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user'
    make[1]: *** [all] Error 2
    make[1]: Leaving directory `/home/janet/nios2-linux/uClinux-dist/user'
    make: *** [subdirs] Error 1
    [janet@localhost uClinux-dist]$
    So I'm assuming I need the
    "e2fsprogs-libs" "e2fsprogs-devel" OR "uuid-dev" libraries ? Or do I need the "uuid.h" header file accessable ??
