22 years agoADC daughter board ?
Hello, I am currently looking for a daughter board (Nios proto header format) implementing multi-channel ADCs. Current sampling rate need isn't high, 1 Ms/s would do for now, but I'...
22 years agoHi bcuzeau,
How handy are you with a soldering iron? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif You could build your own board pretty easily using the following parts from digikey: 1 MAX118CPI [digikey# MAX118CPI-ND, $13.44 CAN] (28-pin DIP, 8-bit ADC, 8-channels, 1Msps, single 5V supply) 1 Proto Board [digikey# V2010-ND, $8.90 CAN] (4" x 4") 2 36x2 Female Header [digikey# 929975-01-36-ND, $4.33 CAN] (36 x 2 female header) 1 wire to do connections 8 connections to your analog outputs (SMA connectors?)
