22 years agoADC daughter board ?
Hello, I am currently looking for a daughter board (Nios proto header format) implementing multi-channel ADCs. Current sampling rate need isn't high, 1 Ms/s would do for now, but I'...
22 years agoI've never seen one.
That said, it wouldn't be too difficult to design your own. analog devices (http://www.analog.com/), ti (http://www.ti.com/), and other companies sell ADCs, and all you need to add to that would be the signal conditioning stuff (Analog Devices or TI again). If your design is simple enough, you could make it on a two-layer board cheaply at expresspcb (http://www.expresspcb.com/). Then you'll be able to get exactly what you want. Just a thought.
