15 years agoActual maximum data rate of Nios w/ 10/100/1000 TSE MAC on Stratix IV
Dear all, Currently I'm developing a Gigabit Ethernet Interface project on Stratix IV which employs Nios (uCOS-II) with 10/100/1000 TSE MAC. This interface project is dedicated to forward data ...
11 years ago --- Quote Start --- We did get 900 mbs using the offset UDP example on a cyclone III..... Ask you rep for the design. Daixiwen probably know about the design --- Quote End --- Hi agdepus and Daixiwen, I have ported udp offload example on DE2-115 board(Cyclone IVE) and speed I am achieving is 231 Mbps. I want to achieve speed of around 700 Mbps but When I increase the speed of PLL clock feeding sys(100 MHz)/pio(35 MHz), .elf file failed to download on the board (.sof file have no problem with downlaoding). I have used fastest Nios in the design. currently I am working on time constraint. What are the other factors which have to be considered to achieve speed around 700 Mbps? why .elf file failed to download on the board after increasing speed?
