19 years agoAccessing SDRAM on DE2
Hi I need to use the SDRAM/SRAM/FLASH. I can use any one the above. I have setup a NIOS II processor with all those peripherals and I have also run a hello_wrld program on the processor. ...
19 years ago --- Quote Start --- originally posted by napster@Jan 15 2007, 03:46 PM hi
i need to use the sdram/sram/flash. i can use any one the above. i have setup a nios ii processor with all those peripherals and i have also run a hello_wrld program on the processor.
now i don't know how to go ahead. i couldn't find any tutorial to do that. where can i get the library files? do i have to write a lot of code to do this? please help me. this is the first time i am working with an embedded processor.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20597)
--- quote end ---
--- Quote End --- Dear Napster, I am also very very new to embedded stuff. Can you please send me your complete project source code & docs at my id [email protected]. The one which uses hello world program. Secondly, If you have used sdram successfully, send that as i require similar work for my project. Thanks in advance regards, aditya
