19 years agoAccessing SDRAM on DE2
Hi I need to use the SDRAM/SRAM/FLASH. I can use any one the above. I have setup a NIOS II processor with all those peripherals and I have also run a hello_wrld program on the processor. ...
19 years agoYou should check out nios ii hardware development tutorial (http://www.altera.com/literature/tt/tt_nios2_hardware_tutorial.pdf).
Page 29 describes simple software development, although I would recommend following the whole tutorial if you've never done this before. After completing this tutorial, you can take a look at creating multiprocessor nios ii systems tutorial (http://www.altera.com/literature/tt/tt_nios2_multiprocessor_tutorial.pdf), which uses SDRAM for a multiprocessor system. You can simply ignore the multiprocessor aspect of it, and focus on getting only one processor to run. Good luck! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
