21 years agoAccessing on chip memory
I recently added 1KB of on chip memory and am trying to write to this location without success. There is still external SRAM in our design; however, I'd like to utilize the on chip memory to mini...
21 years agoNote that if you use bit-31 then you need to mark your data volatile as otherwise the compiler will optimise it out.
It knows that IORD/IOWR are special so will not optimise these out, even when they appear to do something.
