20 years agoAccess to external RAM
I have a system that appears to work at a system clock of 70 MHz but fails to work at 85 MHz. @85MHz, when we run the firmware it behaves in a very strange manner. Often it will get to a specific poi...
16 years ago --- Quote Start --- I have a system that appears to work at a system clock of 70 MHz but fails to work at 85 MHz. @85MHz --- Quote End --- I have a Nios system running @ 80MHz from PLL. I am interfacing to an external asynchronous SRAM with a nominal 10ns access time. I have to use 1 setup cycle and 1 wait cycle to make it work. How is the timing set in your SOPC module?
