11 years agoAccess serial port for data sent from Nios II's uart for real time plotting graph in
Hi all, I am able to read data from FPGA to Nios processor, then transmit this data to Uart component created in Qsys using direct register method (IORD_ALTERA_AVALON_UART_STATUS (UART_BASE)...
11 years ago --- Quote Start --- Hi all, I am able to read data from FPGA to Nios processor, then transmit this data to Uart component created in Qsys using direct register method (IORD_ALTERA_AVALON_UART_STATUS (UART_BASE); IOWR_ALTERA_AVALON_UART_TXDATA(UART_BASE, txdata);etc). Then, I was trying to access serial port data sent from uart in Altera Nios II to plot graph real time in Matlab. I was using this code from Matlab central (http://uk.mathworks.com/matlabcentral/fileexchange/28941-real-time-data-plot-from-serial-port) with minor modification as pasted below: When I run this code I keep getting the following error. What should I do ? ??? In an assignment A(I) = B, the number of elements in B and I must be the same. Error in ==> real_time_data_serial at 80 voltage(count) = fscanf(s,'%f'); I found a few solutions on the web, what I have tried: 1. add pause in .m file so that it has enough time to read the data before the next cycle of data 2. add enough delay at C code where I transmit data to uart 3. make sure the uart has the same setting as comport such as comport number, baud rate, parity, flow control %%real time data plot from a serial port % This matlab script is for ploting a graph by accessing serial port data in % real time. Change the com values and all variable values accroding to % your requirements. Dont forget to add terminator in to your serial device program. % This script can be modified to be used on any platform by changing the % serialPort variable. % Author: Moidu thavot. %%Clear all variables clear all; %%Variables (Edit yourself) SerialPort='com8'; %serial port MaxDeviation = 3;%Maximum Allowable Change from one value to next TimeInterval=0.2;%time interval between each input.0.2 loop=120;%count values %%Set up the serial port object s=serial('com8'); set(s,'BaudRate',9600,'DataBits', 8, 'Parity', 'none','StopBits', 1, 'FlowControl', 'none','Terminator','LF'); set(s, 'terminator', 'LF'); set(s, 'timeout', 10); %%s = serial(SerialPort) fopen(s); time =now; voltage = 0; %% Set up the figure figureHandle = figure('NumberTitle','off',... 'Name','Voltage Characteristics',... 'Color',[0 0 0],'Visible','off'); % Set axes axesHandle = axes('Parent',figureHandle,... 'YGrid','on',... 'YColor',[0.9725 0.9725 0.9725],... 'XGrid','on',... 'XColor',[0.9725 0.9725 0.9725],... 'Color',[0 0 0]); hold on; plotHandle = plot(axesHandle,time,voltage,'Marker','.','LineWidth',1,'Color',[0 1 0]); xlim(axesHandle,[min(time) max(time+0.001)]); % Create xlabel xlabel('Time','FontWeight','bold','FontSize',14,'Color',[1 1 0]); % Create ylabel ylabel('Voltage in V','FontWeight','bold','FontSize',14,'Color',[1 1 0]); % Create title title('Real Time Data','FontSize',15,'Color',[1 1 0]); %% Initializing variables voltage(1)=0; time(1)=0; count = 2; k=1; while ~isequal(count,loop) %%Re creating Serial port before timeout k=k+1; if k==25 fclose(s); delete(s); clear s; s = serial('com8'); fopen(s) k=0; end %%Serial data accessing pause(2); fprintf('here'); voltage(count) = fscanf(s,'%f'); %%For reducing Error Use your own costant voltage(1)=0; if (voltage(count)-voltage(count-1)>MaxDeviation) voltage(count)=voltage(count-1); end time(count) = count; set(plotHandle,'YData',voltage,'XData',time); set(figureHandle,'Visible','on'); datetick('x','mm/DD HH:MM'); pause(5); count = count +1; end %% Clean up the serial port fclose(s); delete(s); clear s; When I check the serial port status, I got the following: Communication Settings Port: COM8 BaudRate: 9600 Terminator: 'LF' Communication State Status: open RecordStatus: off Read/Write State TransferStatus: idle BytesAvailable: 0 ValuesReceived: 0 ValuesSent: 0 I noticed the serial port is ready (since it is open) but no data is sent or receive. Could you please tell me what is wrong so I could try? Please , thank you --- Quote End --- anyone please even a clue for me to try please?
