21 years agoAccess linker symbol from .C file
I'm trying to access a linker symbol from my C file. The idea is to find out where the end of my code and R/O memory is in flash so I can use the remainder for storage. I have the following in my...
21 years agoThe problem you had is related to the fact that you declared the extern variable as "int", that means the compiler will generate GP-relative addressing, that is not the right one in your case.
Take a look at the post "Disabling GP-addressing in generated source code" on this forum... bye PJ
