20 years agoAccesing PC files from UART
Hi everybody, I am working in a project that requires sending datas stored in an internal register implemented into the FPGA to a file in a PC (W-XP). I think the best way is using the UART (11...
20 years agoHi Roberto,
Wolf is right, You should use the uart to transmit your file from nios to your pc On the pc side you will need to write a program that will read this transmitted chars and will write them to a file. Try to read n2cpu_nii5v3.pdf it is found in the document under your installation, you will find there a chapter about UART Try using # include <stdio.h> FILE* fp=fopen(YOUR_UART_NAME,"r+"); fprintf(fp,"what ever you want to transmit on uart"); fclose(fp); This is the way to transmit char over uart. YOUR_UART_NAME was defined as you added the uart component on SOPC You can find this name in a file called system.h The system.h describes your design and can be found under YOUR_PROJECT_syslib\Debug have fun Ilan
