20 years agoabsolute address accessing in NIOS2
HI, eveyone: i just a beginner of NIOS, i have a quetion about software development of absolute address's accessing. for example, the system have one 1kbytes ram, its start avalon address ...
20 years agoHi oceanx,
if I understand what it is that you want maybe I can help you. If you want to give your data an offset en you have a base address, you should do it like this: data = BASE_ADDRESS_OF_RAM_USED | 0x(hex-value); this way your offset should be added with the base adress, which can be found in system.h. And data should be declared as a pointer.... Cheers, Danny
