20 years agoAbout the uclinux starter and memory allocation
dear all,
when i do uclinux according to hippo, now i can run uclinux in my target board(nios2,FLASH8MB(0X000000-0X7FFFFF),SDRAM(8MB)0X800000-0XFFFFFF),but i still don't understand where the zImage file download to,and how does the uclinux work and how does the memory space use? in my target board: 0x000000|------------------| ------------| ----------------- | ------------|8MB FLASH ---- | 0x7FFFFF |-------------------| 0x800000|-------------------| -----------|8MB SDRAM ----| 0xd00000|-------------------| <-----kernal config 0x500000+0x800000,why ?? ------------|--------------------| 0x0FFFFFF|-------------------| 0x1000000|-- NIOS II ------| 0x10007FF |------------------| ---- IN THE SYSTEM THE RESET ADDRESS 0X000000,EXECPTION ADDRESS 0X800020 COULD YOU TELL ME HOW DOES THE UCLINUX WORK WHEN THE SYSTEM POWER ON?1 Reply
You didn't program the flash at 0x000000 yet. You can program the flash, so that will start after power-on without data blaster download/cable.
http://nioswiki.jot.com/wikihome/operating...flashprogrammer (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/flashprogrammer) NOTE, you should not use jtag uart in this case, or it will hang until you run nios2-terminal. you should use serial uart instead. The nios2-download will load the zImage to (0x800000 + 0x500000), and start exec at this address, ie 0xd00000. The zImage will uncompress the linux kernel (gziped in zImage) to 0x800000. And start exec at 0x800000.
