21 years agoabout the NIOS II IDE
About the Address of the TIMER_CONTROL and TIMER_STATUS: in my SOPCBUILD, the TIMER_0_BASE = 0x4800(18432) So ,I think the address: TIMER_CONTROL: 0x4800(18432)+2 = 0x4800(18432)+2 ...
21 years agoHi xc214043,
> because in some resource, it told me the_timer is 16-bit aligned, so i think You're probably referring to the "Nios II Altera Embedded Periperals Handbook", which shows the registers as being 16-bit -- and they are 16-bit registers. However, each 16-bit register is mapped to a 32-bit word ... the registers are aligned on 32-bit boundardies. > now, i am puzzle. > > can you give me some imformation about this Open your ptf file in a text editor and take a look at the timer module. You should see the following:Address_Alignment = "native";
Data_Width = "16"; Then get a copy of "Quartus II Handbook, Volume 4, SOPC Builder" and read the section entitled, " Native Address Alignment & Dynamic Bus Sizing" in chapter 3. Specifically, look at Table 3-2. This should answer all of your questions. Regards, --Scott
