19 years agoAbout the nios-elf-gcc problem
I install the tools CDK4NIOS and use nios-elf-gcc to compile the U-Boot-1.1.4.For the test,I input: make DK1C20_config make ...... The follow message is like this make[1]: Entering dire...
19 years agoIt seems OK.
You may also try out the latest u-boot release 1.1.5 . Next you will need to download to sdram, and try out. Then you need to learn to program u-boot to flash. You may search the forum and find a lot of helpful posts from Scott. During your learning, it would be great if you can take down your experience on the wiki. Finally, welcome to the wonderful world of Nios II.
