20 years agoabout the IRQ
when i use the pio interrupt,it need a long time for the request . the system act so slow. could anyone help me?
20 years agoAlternately, you could start with a full_featured design, which locates the HAL's exception handling code in a tightly coupled memory (an onchip RAM that should be just as quick as cache). If you're using >=5.0 Nios II/Quartus II, you should also be able to place the exception stack and, with some effort, your own ISR, there, as well!
Best of luck! Cheers, - slacker
