20 years agoabout the head file io.h in the nios2 ide
Hello:
i created a project template "hello led" in the nios2 ide.then i see the content of the io.h file.there are something i don't know what they are. for example:# define IORD_32DIRECT(BASE, OFFSET) __builtin_ldwio (__IO_CALC_ADDRESS_DYNAMIC ((BASE), (OFFSET))) what does "__builtin_ldwio"mean?what is the usage of "__builtin_ldwio"? where can i find the information about"__builtin_ldwio"? thank you!1 Reply
i have found the answer from altera.
this is altera's reply: These built-in functions now are used instead of doing direct peripheral register access. They mean reading/writing register REGNUM offset from base address BASE. They use LDxIO or STxIO instructions. Please find the detailed Nios II instruction set reference in NiosII Processor Reference Book ( <NiosII Installation Path>\documents\n2cpu_nii5v1.pdf, chapter 8).
